5 members (Bill Hanlon, Wickedbass, tclederman, Donf, TexasJim50), 55 guests, and 0 robots.
Topics128,075
Posts1,055,916
Members48,429
#68965 11/21/2006 11:55 AM
Would like to install a duel master cylinder on my 1942 Chevy 1-1/2 ton truck, has any tried this and how is it done??? You can call or e-mail at 262-392-2989 or [email protected] Thanks for your help!!!
Marv.
#68966 11/21/2006 9:38 PM
Riding in the Passing Lane
If it has a power booster you will need 2 of them.
1972 Chevy c10 Cheyenne Super
#68967 11/22/2006 1:37 AM
I just made a bracket under the floor to mount a booster/master to where the old master was. Plumbed new lines and made a new adjustable pedal rod. The booster and master were from a 70 C10 with drum/drum brakes. This set-up is actually fun to drive as apposed to my other one that's stock and a little "iffy" in brake pedal feel.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#68968 11/22/2006 3:08 AM
Marvin,
Check these guys out at ABS Power Brake 233 N. Lemon St. Orange, CA. 714-771-6549. www.abspowerbrake.com
They have conversions for power or non power applications. They know their stuff and are great to work with.
Fred
#68969 01/16/2007 8:03 AM
I am installing a duel master cylinder on a 49 chevy half ton.
Any one out there ever done this conversion?
I'm in the process of a ground up restoration and would like to keep the trucks original brakes.
Thanks.Paul Grice
