1 members (FAST55),
133
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68965 11/21/2006 11:55 AM | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Would like to install a duel master cylinder on my 1942 Chevy 1-1/2 ton truck, has any tried this and how is it done??? You can call or e-mail at 262-392-2989 or [email protected] Thanks for your help!!! Marv. | | |
#68966 11/21/2006 9:38 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it has a power booster you will need 2 of them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#68967 11/22/2006 1:37 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I just made a bracket under the floor to mount a booster/master to where the old master was. Plumbed new lines and made a new adjustable pedal rod. The booster and master were from a 70 C10 with drum/drum brakes. This set-up is actually fun to drive as apposed to my other one that's stock and a little "iffy" in brake pedal feel. Good luck, Scott | | |
#68968 11/22/2006 3:08 AM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Marvin, Check these guys out at ABS Power Brake 233 N. Lemon St. Orange, CA. 714-771-6549. www.abspowerbrake.com They have conversions for power or non power applications. They know their stuff and are great to work with. Fred
#68969 01/16/2007 8:03 AM | Joined: Nov 2006 Posts: 9 New Guy | | New Guy Joined: Nov 2006 Posts: 9 | I am installing a duel master cylinder on a 49 chevy half ton. Any one out there ever done this conversion? I'm in the process of a ground up restoration and would like to keep the trucks original brakes. Thanks.Paul Grice | | |
