9 members (Bogart's Truck, Donf, TexasA&M48Truck, kades51, jmoore, Gdads51, Otto Skorzeny, 2 invisible), 96 guests, and 2 robots.
Topics128,132
Posts1,056,379
Members48,441
#688393 10/22/2010 5:50 PM
Hey there, I am new to the forum here. I have always had an obsession with old vehicles and have a small collection of them myself. I am yearning for a 4wd K30 or something of the sorts. In the mean time I am obsessed with the old Eaton axles. I have an itch for them that I just seem to buy them whenever I come across one. IMHO they are the best designed truck axle and its a shame they stopped producing them and went to the 14 bolt.
Anyways, Just saying hello!
The Eaton Axle Guy
AlexJ #688403 10/22/2010 6:27 PM
welcome from Tx
Redryder pix
My Hotrod
joker #688465 10/22/2010 11:15 PM
Leo Offline
Moderator
Moderator
Welcome.
Leo
Leo #688823 10/24/2010 11:27 AM
Joy Offline
Welcome to Stovebolt! Some guys collect stamps of old trucks, some collect postcards of old trucks, you collect Eaton Axles!Hope you have a big barn to store your collection in. grin What trucks do you see them on?? ohwell Anyways, good luck and have fun here! wave
Joy #688851 10/24/2010 3:08 PM
Thanks! Already folks seem great on this forum. I dig them out of '46 - '72 3/4 Ton and 1 Ton trucks. I am in the process of building my own version of the Napco front axle except instead of closed ball knuckles I am using Dana 60 King Pin knuckles.
I have one in a 4 link setup in my Jeep already. Awesome axles. And yea, I have them in pieces in my shop, some assembled outside, some on racks in my seperated shop, and even a few at my grandparents farm.
Heck, as I type this I am getting ready to go out in my shop and finish cleaning up a 4.10 third.
The Eaton Axle Guy
AlexJ #688894 10/24/2010 8:03 PM
AlexJ, Welcome to the stovebolt page. Great place to hang out and always something new to learn. I'm sure your expertise will come in handy. Probably soooner than you think!!
Welcome!!
Question: Do you find any Eaton's with lockers? I guess they are rare.
Professional Novice
Frank50 #690419 10/30/2010 4:35 AM
i'd like to know about the lockers as well.
Robert
Robert French MY3800FIRETRUCK
AlexJ #691031 11/01/2010 7:19 PM
hello axle junky,i have a 67 1 ton with a ho72 and factory detriot no spin. can't find any info ohter than all the paper work that was in the glove box.i was the first one to open the envolope!
I got on Randy's Ring and Pinion site and I did not see any aftermarket lockers for that axle, but I think he used to offer them. Maybe not enough demand... I would be interested in one for my 50 3600.
Professional Novice
Frank50 #691193 11/02/2010 4:17 AM
these axles are still used by some in the rock crawler crowd. i've lurked in some of their forums & some of them say a 14 bolt carrier & 35 spline axles can be put in the earlier housing. from what they say shaving the ends of the axles ( they're slightly long ) is all there is to it. almost a bolt in.
bluechev #706929 12/28/2010 10:23 PM
I'm sorry that I hadn't seen all of the activity on this thread about the lockers and the possibility of the swaps. There were some of these axles with factory No-Spin lockers manufactured under the "Trach-tech" name by Eaton. Later the differentials were upgraded to the Detroit name when full case lockers became available for other applications outside of the factory Eaton. The original no-spin is still being replicated by many many other companies. The cheapest way to install one of these aftermarket lockers is to aquire a set of GM 14 bolt axle shafts of similar length to the housing you have, whether it be a DRW or SRW housing. The shafts are 1/4" or so too long to work properly, in some applications, but have been known to slide right in for other folks. Some just use a chop saw to cut the ends off square but if you know ANYTHING about axle shaft spline theory you would know this is a BAD idea. Instead shims should be used behind the flange between the hub and gasket to offset the shaft to keep it from bottoming out on the housing. I can manufacture said spacers
AlexJ #788093 10/12/2011 4:24 AM
Welcome , i like the 1967 chevy trucks and Eaton rearends 4:57 and 4:11 , would not want 6:17 5:38 5:14
