0 members (),
127
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Well, just finshed up 2-1/2 days worth of effort stripping the rear fenders and bed on the '65. I used a Norton Rapid Strip wheel on my 4-1/2" angle grinder. They are great, if you haven't tried these you owe it to yourself to give them a try. Man what a dirty job! I must say I am diggin' the look in bare steel though. I have a half a notion to just wipe it down with Gibbs and say Done! http://www.roadsters.com/gibbs/For a picture go to post #148 of my build thread http://67-72chevytrucks.com/vboard/showthread.php?t=363509&page=6
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Spent 3 weeks stripping/sanding/straightening both rear doors on the burb. Today I painted the inside/jambs. Tomorrow if the weather cooperates I will attempt to paint the outside. The doors have been off for 6 years, can't wait to get them back on! | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | In Sept. I took my MAR-K box metal parts to the painter.Last saturday I parked the truck in its winter repair/storage place, after I get off this time waster(computer), I will organize my new reproduction door hardware and on saturday will start fixing the door latches ect. Next month or 2 I should be removing the old box, sending the rear fenders and running boards out for repair and paint.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Nov 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 67 | Hot Rod John...just do the bare steel!! You know you want to. My '54 is staying in bare steel but I will be clear coating it for better protection. I currently have my bare parts covered in Evapo-Rust. Been sitting for a month or so now and the parts that have been covered have no rust at all. But I did scratch a fender a little when moving them and rust started to appear. So that tells me the stuff does work when applied, but like everything you have to let them sit awhile before moving them incase you scratch them or wipe off the liquid by accident. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Had to take several weeks off for honey do's and farm chores. Got a chance to finish steering and mounting column, brake booster and master cylinder, inner fenders require some trim and fitting. Picked up the freshly primed bed. I need to fab brake pedal and complete brake line routing, finish fuel tank mounting, put bed together and set on frame and ......the list goes on. LOL | | | | | Joined: Jul 2010 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 36 | After getting plates on my '49 , the 235 let go. Went on craigslist Sunday & scored a 235 with 20,000 on a rebuild. Finally took Neo for a spin today (Thurs.) with my mom. Other than being a little noisy, she enjoyed it. Then went to show my truck off to a friend. Went to gas station & chatted with 4 strangers & got one purchase offer. It has been one heck of a day! | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Got the 4 spd in today...Whew...what a heavy piece compared to the 3 spd. | | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Got my 1951 Owner's Manual, Shop Manual and Assembly Manual delivered today.
Will be doing some reading this weekend. | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Got my motor started today!!!!!!!!!!!!!!!!!! 30 min @ 2200 RPM (it didnt fly apart) purred real nice. Now comes the rest. Don't know how to load pics ... sorry
Mike | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Decided to remove the the 2 bottom leaves in the rear leaf pack. One was about 10" long and the next one was about 18" long. Made a 5/8" lowering block (approximate thickness of the 2 removed leaves) and bolted everything back up. The ol' 38 sets a lot better (always thought it was way too high in back), and a good test drive offered up a lot smoother ride. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I am in the midst of a frame off stock restoration of my 1950 COE grain truck. Started 2 1/2 years ago and it now moves on its own power. Built a temporary platform to sit on the frame superstructure and went for a drive today around the half mile loop the shop is on. Everything went well, the brakes are awesome (stock with hydrovac). Tomorrow I drive 3/4 mile up the road to the guy who is painting the cab and we will drop the cab on this weekend. I can't wipe the smile off my face, I wonder why? | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Weather cooperated today and I was able to finish painting both rear doors on my burb. Now if I can be patient, let the paint dry and put them back on come monday. | | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | Brought mine home so I can start, lol | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | http://s783.photobucket.com/home/johntsmith1056I got the bed completely disassembled, sanded down, rust proofed and primed. Then I used a roll on bed-liner on the inner sides. A little messy to use, but the results were great. I had trouble getting masking tape to stick to it so I could paint the non-coated outer parts, so now I have some overspray on the liner that will need to be touched up. Glad I have some coating left over to use on this. Meanwhile Sunday we took her for a ride, sans bed, about 25 miles to donate blood. I am still having trouble with the steering box adjustment. I have it a little too tight and have to constantly make steering adjustments. This added to the play in the wheel makes highway driving a real chore.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I can feel your excitement! O HAPPY DAY! CONGRATS! | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I'm still a ways off, but trying to be ever so patient. I'm in the middle of breaking down my '58, 235. Yesterday evening I hand-polished the camshaft then oiled, tagged and bagged it. Hopefully today, I can do the same for the crankshaft. Baby steps... | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | Test fit the disc brake conversion kit to the front axle on the '39 GMC. Had to notch the caliper brackets to fit around the steering stops. Pulled everything back apart, primed and painted. Plan to have everything back together this week and put the whole assembly back under the frame. Then it will be on to the rear suspension and axle. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Putting my cab together. Electric wipers, firewall pad, defroster vents and fresh-air heater so far. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Got a free set of rear drums, a complete third member, a free radiator, new headliner, new sunvisors, and a used but good tailgate today. Removed front drums to inspect and make a replacement list, cleaned frame, removed all original wiring
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | More grinding and welding. The rear stake pockets on my stepside were butchered by the PO. I made some 1-1/2 x 2 rectabgular tubes out of some 2 x 2 tubing. Then cut the stock openings slid the new tubes in, welded and ground them flush. Here's a photo: http://inlinethumb14.webshots.com/29005/2466836390103882008S600x600Q85.jpg
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Now that's some fancy work there...
~Jim
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Tore the wheel cylinders apart and honed them...looks like new kits will be ordered, not new cylinders. Re-installed axle and third member, started engine and shifted thru the 4 spd gears and new clutch...all works good. | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | removed the bed and fender from my 53 3100 parts truck. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Still hand cleaning and bagging parts for storage from the '58 235 engine. So far, camshaft, lifters, screws and bolts, pushrods, connecting rod and main bearing caps, crankshaft... (taking a breath). Next will be the rocker assembly and pistons. Still a lot left to go and yet the '59 engine waiting to be disassembled. I hope to get a lot done this weekend! Still LOVING it! | | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | Arranged a couple of PBR cans artistically on the front fender.
| | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Pulled an SM420 for my '50 from one of Stovebolter garandboy's parts trucks. Good times. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I finally got the rear main seal for my Suburban today. Got it installed and the covers on. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Now that I have risen back from the dead, recently installed the torque tube and tranny with help of nrdesieyes this past Sunday. Yesterday was tranny support, spark plugs, rear axles, differential cover. Today I'm dumping in oil in both diff and tranny and fire the green turd up.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Picked up my seat at the upholstry shop. Picture from my cell phone": Looks good BIG.....I'm assuming the guy in the pic is the dude who did the work, why is it most good upholstery guys seem to come from 'south of the border'?? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Jock, It's because they come from Southoftheborder. I set it in the cab and hopped up on it. It fit really good, however at 6'1 I have gotten use to a little more leg room. With the gas tank in the back and the seat back as far as she will go, there's no adjustment. It will work out as my wife will be able to drive it as well.
~Jim
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Replaced the headlight rings. I noticed that there is a big difference in the attachment brackets than the originals where. | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Still cleaning and bagging/storing parts from the '58 235. Rocker arm assembly, pistons timing gear and cover, front plate... etc. Hopefully today I'll have the rocker cover, water pump and oil pan cleaned. I still have 5 out of 6 pistons/connecting rods to free-up. I'm ready to mount the block onto the engine stand, give it a good going over and AT LAST get to the '59 235! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good looking lkay3. Anyone wanting to stay relatively original with good safe brakes should look at your setup.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | The wiring continues,i'm only managing a bout 3 hours a week on the truck at the moment.Not through choice though. I've got all my gauges,steering column and engine bay done. I hope to get the rear end done tomorrow.
Just to 'throw a spanner in the works, I dropped one of my front parking light lenses as I was removing it,you can work out the rest......... Thankfully a replacement is on the way and didn't break the bank. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
