| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | I have a question about loading a lawn tractor into the bed of my 1957 3100. What is the best way? On todays trucks you put ramps on the tailgate and drive it up. Can we do this with a 1957? Will the chains hold?
Thank you, Kevin | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Drop the tailgate down. Don't use it. Put ramps directly or as near as possible to the bed. If you have a way to lock the ramps onto the rear sill area, that's even better.
Drew
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Most mowers I've seen will drag the deck on the bed at the steep angle you'll have. Just an FYI.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put a little RV type winch in the front of the bed. It pulls it right up the ramps. Also good for motorcycles. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I loaded one in my 52 when I had it, no big problem, I backed up to a lower spot in the ditch,put some 2x6 for my ramps and pushed it right it................but then I had to unload it.. I forgot my truck was lowered and the fenders were now touching the tires......man, I was peeved after all the pushing and lifting I did to get it in... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | Thanks to all for the help. An older gentlemen wants to give me his lawn tractor and I want my truck to do the hauling. I just havent been able to figure out a safe way to load and unload. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Turn off the blades before loading it. LOL
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Ramps in combination with backing up to a bank/hill, or with the wheels in a ditch is a good method.
I've used the forklift several times to load and unload mowers, just back the mower on the forks, pick it up and roll it off into the bed, repeat for unloading. Even if the forks aren't long enough to reach under the front wheels the deck sits on the forks and it works just fine.
Grigg | | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | If you have the right size ditch available park the truck in it place your ramps and drive almost straight in with little to no angle. This also works great for flatbead trailers when loading or offloading again though you need the right ditch. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Like Drew said, it's helpful if you have a way of locking the ramps in place. You don't want one of them slipping off the tailgate or the truck bed when you're halfway up the ramp. Don't ask me how I know this!! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Make sure that when the tailgate is down (not hanging on the chains) that there is no weight on the tailgate. If the tailgate is resting on a bumper and you load putting pressure on the tailgate, it will damage the tailgate. | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | I don't know if you want to go the way I do it, but: tip the the mower over on its rear. back truck up close to the Mower. push it over so front wheels rest on the edge of the bed. lift up rear and shove in. while doing all this make sure it's in park! only requirement you have to be able to lift about 300 pounds | | |
