6 members (59 fleet, diseasel, 48jim1ton, Otto Skorzeny, Bill Hanlon, 1 invisible), 117 guests, and 3 robots.
Topics128,035
Posts1,055,556
#687325 10/19/2010 2:29 AM
I have a question about loading a lawn tractor into the bed of my 1957 3100. What is the best way? On todays trucks you put ramps on the tailgate and drive it up. Can we do this with a 1957? Will the chains hold?
Thank you,
Drop the tailgate down. Don't use it. Put ramps directly or as near as possible to the bed. If you have a way to lock the ramps onto the rear sill area, that's even better.
Drew
Ex Hall Monitor
Ex Hall Monitor
Most mowers I've seen will drag the deck on the bed at the steep angle you'll have. Just an FYI.
Riding in the Passing Lane
I put a little RV type winch in the front of the bed. It pulls it right up the ramps. Also good for motorcycles.
1972 Chevy c10 Cheyenne Super
I loaded one in my 52 when I had it, no big problem,
I backed up to a lower spot in the ditch,put some 2x6 for my ramps
and pushed it right it................but then I had to unload it.. I forgot my truck was lowered and the fenders were now touching the tires......man, I was peeved after all the pushing and lifting I did to get it in...
Redryder pix
My Hotrod
Thanks to all for the help. An older gentlemen wants to give me his lawn tractor and I want my truck to do the hauling. I just havent been able to figure out a safe way to load and unload.
Turn off the blades before loading it. LOL
Dennis
Ramps in combination with backing up to a bank/hill, or with the wheels in a ditch is a good method.
I've used the forklift several times to load and unload mowers, just back the mower on the forks, pick it up and roll it off into the bed, repeat for unloading. Even if the forks aren't long enough to reach under the front wheels the deck sits on the forks and it works just fine.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
If you have the right size ditch available park the truck in it place your ramps and drive almost straight in with little to no angle. This also works great for flatbead trailers when loading or offloading again though you need the right ditch.
Like Drew said, it's helpful if you have a way of locking the ramps in place. You don't want one of them slipping off the tailgate or the truck bed when you're halfway up the ramp. Don't ask me how I know this!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Make sure that when the tailgate is down (not hanging on the chains) that there is no weight on the tailgate. If the tailgate is resting on a bumper and you load putting pressure on the tailgate, it will damage the tailgate.
I don't know if you want to go the way I do it, but:
tip the the mower over on its rear. back truck up close to the Mower. push it over so front wheels rest on the edge of the bed. lift up rear and shove in.
while doing all this make sure it's in park! only requirement you have to be able to lift about 300 pounds
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
