3 members (Gray_Ghost, Steelonsteel, Gdads51), 46 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#687025 10/18/2010 12:17 AM
My 54 6400 has a fuel tank that is welded to the out side of the frame (it is actually a fuel oil tank). It has been sitting for years with nasty fuel in it and about 1/8" or more of gunk in the bottom. There is a 5/8" drain plug in the bottom so I can drain the nasty fuel but that still leaves the gunk. Anyone have an idea on how to remove the gunk while leaving the tank in place?
A little fresh gas would probably help but how about some acetone and shake it around.
Edit:... how about sticking a pressure washer wand down in it to.
Put a new one in the cab and never have fuel supply issues again!,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I agree with Scott. Put a Spectra Premium tank behind the seat and that will fix it.
