| | | Forums66 Topics128,090 Posts1,056,026 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 30 New Guy | | New Guy Joined: Nov 2009 Posts: 30 | My 54 6400 has a fuel tank that is welded to the out side of the frame (it is actually a fuel oil tank). It has been sitting for years with nasty fuel in it and about 1/8" or more of gunk in the bottom. There is a 5/8" drain plug in the bottom so I can drain the nasty fuel but that still leaves the gunk. Anyone have an idea on how to remove the gunk while leaving the tank in place? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | A little fresh gas would probably help but how about some acetone and shake it around.
Edit:... how about sticking a pressure washer wand down in it to.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Put a new one in the cab and never have fuel supply issues again!, Scott | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I agree with Scott. Put a Spectra Premium tank behind the seat and that will fix it. | | |
