1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68567 11/14/2006 4:53 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I'm posting a few pictures of my t-5 transmission installed.I modified the crossmember and rewelded some 1/4" plate in it.I used my mig welder to weld in the piece on the transmission access panel. t-5 tranny installed b&m short throw shifter transmission access panel modified 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#68568 11/14/2006 4:59 AM | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | | | |
#68569 11/14/2006 6:35 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Tim - Looks like you got it! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#68570 11/14/2006 4:13 PM | Joined: Sep 2006 Posts: 29 Junior Member | | Junior Member Joined: Sep 2006 Posts: 29 | Looks like a real sweet setup, you did'nt have to tweek the shift rod with that B&M shifter, NICE !!
Those who fail to plan, plan to fail....
#68571 11/14/2006 11:47 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The shifter has been tweeked in the pictures.It was hitting the seat,so i took it apart and heated and bent it.Was still unhappy with the heighth of the shifter,so i cut it and lenghthened it last night.will post some pictures of my modified shifter soon.
Thanks for the kind words,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#68572 11/15/2006 12:17 AM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Tim, Did you use a 45049? I'll be swapping my shifter eventually and that looked like the most logical application. If so, how much did you lengthen the shaft? | | |
#68573 11/15/2006 1:16 AM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Tim, Looks great! Do you have a picture of the front side of your modified cross member. It's a little different than others have done. Looks interesting. | | |
#68574 11/15/2006 3:09 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | tlorber,it's the bnm45049 shifter for an s10.I had an old broken shifter from a 1966 chevy truck i use to own.I incorporated it into my t-5 shifter.I cut the 1966 shifter in two places.First cut was just below the threads for the knob.I wanted the b&m knob and the threads are different than a 1966.The second cut was 8 3/4" off the bottom of the 1966 shifter.I used a caliper to determine where to cut the b&m shifter,so the 1966 shifter and the b&m where the same diameter when welding together.The shifter is about 23 1/2" from the top of the base to the end of the shifter knob threads. 46forme,i can take some pictures of the front of the crossmember,but it looks like the rear of it.I know it only bolts into the frame one way,it's slightly tapered.I drilled a hole on top side for the mount stud to slip into.I then drilled a larger size hole on the bottom side,welded a large washer to it,so a 15mm socket can tighten the mount nut.The mount is bolted to the quarter inch plate i welded in.This is what i thought up,never done it before.Do you think it's ok ? front of crossmember I ground my welds down,heated and bent it,then primered it tonight.I installed it to see how it felt.I have'nt drove the truck yet,but it feels good just sitting in it and going through the gears.You could actually use a stiff wire or a coat hanger and bend it to get your heigth.This was all trial and error for me. Here are a few pictures of it. 1966 & b&m combination primered modified shifter Hope this helps. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#68575 11/15/2006 8:46 PM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | Love these posts with pictures, and thanks for the B&M part number. Dave | | |
#68576 11/17/2006 2:09 AM | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Tim, Bolting the tranny into the member eliminated the need for spacer plates between the frame and some hole drilling. Way to go - another way to skin the cat. Question: did you look at other options on the short throw shifter, Hurst, etc? If so what was the motivating factor for B&M? Anybody have any ideas on other applications with long shifters and short throw kits, i.e Jeep T-5's etc. Brett | | |
#68577 11/17/2006 2:59 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I did look at the hurst,then looked at the b&m.The look of the b&m and there reputation and the price was right.But of coarse,i changed the look of the handle. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#68578 11/17/2006 12:27 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Maybe I missed it Tim, I haven;t had time to look at all the pics, dial up ya know. But what year is the truck and engine? Denny Graham Sandwich, IL
Denny G Sandwich, IL
#68579 11/17/2006 3:07 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | denny,it's a 1951 3100 chevy and i have the original 216 engine in it.I'm getting ready to put a 1954 261 in it. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#68580 11/17/2006 11:59 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Tim, that's really looking good. I'm curious on you short throw shifter: If you measure with a tape measure up on the shift knob, what's the total distance between 1st and 2nd? Thanks, john. | | |
#68581 11/18/2006 1:19 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | John,at the base of the shifter it is only 1/2" travel. At the very tip of the knob it travels 7 1/2". Keep in mind i altered the shifter handle.I wonder what the travel would be with the original shifter and the handle i made ?
You have one beautiful truck there !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#68582 11/18/2006 3:59 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Thanks Tim! On my t-5 install: I bent the bottom portion so it wouldn't hit the seat and screwed the s-10 stick shifter back on. I have 8" of travel from 1st to 2nd up on top at the knob. | | |
#68583 11/18/2006 4:07 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Since you are using the stock shifter and s10 shift handle.A taller one would mean even more travel.
Thanks for the information,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
