| | | Forums66 Topics128,081 Posts1,056,071 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have a farm tank that I purchased at auction and it had some leakage around the outlet. After sandblasting and painting it I am now ready to put it to use but want to be sure the leak is stopped. I replaced the reducer bushing which was very short with a new one and used pipe dope on the threads. As for the welded tank bung I want to put something on it but don't know what is best. If anyone has some experienced advice from your old Chevy truck tanks I would appreciate it. Thanks.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dave, short of pouring in some sealer I'd suggest a good coat or two of POR15. After cleaning my 37 tank it had several pin holes. I ended up using the sealer kit inside and then put a good coat of POR15 on the outside....that was over 10 years ago and I have never had any problems of any kind out of my tank and I do drive my truck quite regularly.
I might add that on my 37 the tank sits down under the seat, I can take the cap off and look straight down into the tank. The sealer looks as good and smooth, no signs of any cracks, as the day I poured it in.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I bought a reproduction tank that is a metric fitting (nice touch jerks)for my 50' and after repeated attempts to seal I used J-B weld on it. Leak sealed! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Good advice guys. Thanks. | | |
