BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
7 members (cmayna, festerhairball, Peggy M, Ponchogl, homer52, Leo, Gdads51),
528
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,264 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Sep 2010 Posts: 575 Shop Shark | Shop Shark Joined: Sep 2010 Posts: 575 | http://picasaweb.google.com/wmhatfield/MyUnnamedToyProject#5525800576502467202I have evidence of fluid through both wheel seals and the pinion seal... after reading some posts on here (and thank God I did) I decided to look for this vent, which I had previously not encountered. If this indeed is the vent, is there something missing?? Just a hole on the top of the shaft? Surly there must be some protection from elements that I don't have. Mark | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yep, something missing .... the vent  should be a small 'tube' in that hole with a cap on it that fits loosely, held on by a crimp - lets air out without letting road junk in Bill | | | | Joined: Nov 2005 Posts: 6,061 'Bolter | 'Bolter Joined: Nov 2005 Posts: 6,061 | Hy Bigtonka, that picture is of a hole, where the vent should be. If you know what size the hole is [1/8" or 1/4" pipe thread] you can probably get one at your local Napa, hope that helps. | | | | Joined: Sep 2010 Posts: 575 Shop Shark | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks guys!
I couldn't tell - or perhaps I didn't look hard enough, but is it that hole threaded? It looks like 1/4" for sure.
Mark | | | | Joined: Jun 2010 Posts: 188 Shop Shark | Shop Shark Joined: Jun 2010 Posts: 188 | If it is threaded and you need to clean up the threads with a thread chaser or tap here's a good tip. Put some grease on your thread chaser. Any loose stuff or metal chips will stick to the tap and not fall inside. Go to your local NAPA. Tell them you need a vent for your rearend. They have some awesome catalogues to look through. That'll give you some options. | | | | Joined: Sep 2010 Posts: 575 Shop Shark | Shop Shark Joined: Sep 2010 Posts: 575 | Gotfasd - I had to laugh - I was reading your post, and the reread it to my wife - the part about needing a vent for my rearend... she agrees 100%. | | | | Joined: Feb 2008 Posts: 829 Shop Shark | Shop Shark Joined: Feb 2008 Posts: 829 | My wife seems to think I need a plug for mine.  | | | | Joined: Feb 2009 Posts: 400 'Bolter | 'Bolter Joined: Feb 2009 Posts: 400 | Mine tells me I need a muffler for mine.  | | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | To change the subject, the vent on my 1 Ton has a little tube with a one way flap inside. I removed it and tested it. It lets air out but not in. | | | | Joined: Mar 2005 Posts: 171 Shop Shark | Shop Shark Joined: Mar 2005 Posts: 171 | my wife tells me i am a rear end!!!!! Robert. | | | | Joined: Jun 2010 Posts: 188 Shop Shark | Shop Shark Joined: Jun 2010 Posts: 188 | I am delighted to be the butt of your jokes. LOL!!! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | Shop Shark Joined: Jun 2009 Posts: 2,201 | | | |
