Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Woodcmiami, newtonlr, moparguy), 613 guests, and 1 robot.
Topics126,776
Posts1,039,259
Members48,100
Most Online2,175
Jul 21st, 2025
http://picasaweb.google.com/wmhatfield/MyUnnamedToyProject#5525800576502467202
I have evidence of fluid through both wheel seals and the pinion seal... after reading some posts on here (and thank God I did) I decided to look for this vent, which I had previously not encountered.
If this indeed is the vent, is there something missing?? Just a hole on the top of the shaft? Surly there must be some protection from elements that I don't have.
Mark
yep, something missing .... the vent big_eek should be a small 'tube' in that hole with a cap on it that fits loosely, held on by a crimp - lets air out without letting road junk in
3B Offline
Hy Bigtonka, that picture is of a hole, where the vent should be. If you know what size the hole is [1/8" or 1/4" pipe thread] you can probably get one at your local Napa, hope that helps.
Thanks guys!
I couldn't tell - or perhaps I didn't look hard enough, but is it that hole threaded? It looks like 1/4" for sure.
Mark
If it is threaded and you need to clean up the threads with a thread chaser or tap here's a good tip. Put some grease on your thread chaser. Any loose stuff or metal chips will stick to the tap and not fall inside.
Go to your local NAPA. Tell them you need a vent for your rearend. They have some awesome catalogues to look through.
That'll give you some options.
Gotfasd - I had to laugh - I was reading your post, and the reread it to my wife - the part about needing a vent for my rearend... she agrees 100%.
My wife seems to think I need a plug for mine. not me
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Mine tells me I need a muffler for mine. dang
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
To change the subject, the vent on my 1 Ton has a little tube with a one way flap inside. I removed it and tested it. It lets air out but not in.
1951 1 Ton Completed
my wife tells me i am a rear end!!!!!
Robert.
Robert French MY3800FIRETRUCK
I am delighted to be the butt of your jokes. LOL!!!
Tee Hee, he said butt.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Moderated by  Dusty53
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.467s Queries: 14 (0.031s) Memory: 0.6550 MB (Peak: 0.7479 MB) Data Comp: Zlib Server Time: 2025-09-22 01:42:28 UTC
Valid HTML 5 and Valid CSS
