2 members (dt235sd, JW51),
204
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | Okay, so all you out there that have done interior work on your burbs must have run across this situation. The rust inside the door panels and rear interior panels makes it tough to remove screws without breaking them in half. While most of the time a good shot of liquid wrench helped, I have a half dozen or so that broke inside the panel door or rear quarters.
Looking for your recommendation about the easiest and less damaging way of getting them out, leaving the retaining insert intact. Send me your genius!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | TIG weld something on the end of the screw enough to grab it with vice grips and often effortlessly remove them.
the welding heats the screw and the thought is that it expands in the hole and crushes the rust some, making it a little freer and easier to remove.
All I can say it is works 98% of the time, I've removed hundreds of broken fasteners with this method, and can only think of a couple where it hasn't worked.
Grigg | | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | Is there a non-welding option? | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Heat is where it is at.
I have been able to heat mine with a propane torch and then use vice grips to grab and remove all of mine, in my Suburban, without welding. Try a propane torch first and see where it gets you.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Is there a non-welding option? There are some, but there is no comparison to the welding option. The same method I use with the TIG can be done with a MIG welder, although not as easy on the hard to get to ones, or screws broken off below flush. Even a stick welder will work if you're good enough, or if the bolt is large enough.. I've tried them all on broken bolts and screws, and prefer the TIG welder. There are some pretty affordable MIG welders available, even small ones that run on 110V would help remove screws. Grigg | | | | | Joined: Sep 2010 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 42 | I agree, welding is about the best way. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I may be a bit late here but i have used a propane tourch and ice water to free up rusted screwes and bolt's and brake bleeder's. Have the ice water in a quench bottle works well,heat then cool heat then cool usually after awhile it will come.Having a lot of patience help's
layback
| | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | Thanks all.
My biggest issue is small bolts that broke off inside the door and rear interior panels, with very little or nothing sticking out to grab onto. Heat will certainly help loosen, but then I have to figure out how to turn them with little to grab onto. | | | | | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | If the screws or boltheads are broken off, I drill a hole and use an ez out. Or if the bolt head is rounded off I have a set of craftsman gripper sockets, these work well. I agree with using the heat first.. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | left hand drill bits work well on small stuff. Use drill in reverse & slow speed. | | | | | Joined: Oct 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 83 | A fellow Bolter and local buddy (same guy) told me of a way to get stuck bolts out, I'm sure it will work with screws as well, the trick is to do this BEFORE you bust or otherwise make the head of the fastener un-usable or broken. I went to a local hardware store and got some Bee's Wax, heated the stuck fastener using a torch and applied the bee's wax to the head of the fastener. The Bee's Wax wicked into the joint and the fastener was freed up pronto! I used this on the door hinge bold on my 57 GMC 100 panel, works like a charm! Thanks Greg! PS: WD-40 didn't do a thing.
1999 GMC Yukon 1957 GMC 100 Panel
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | WD-40 is mostly for a lubricant not a penetrant. WD stands for "water displacement" (test #40) and was invented by/for the space program of some sorts. Got to remember the bee's wax think. I could have saved a lot of quarters that went into the swear jug. | | |
