10 members (JW51, Gdads51, artinva, Peggy M, VicZ, Ridgeback, RAC1812, Shaffer's1950, klhansen, 1 invisible),
122
0
Mod | | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I've been getting 11 to 12 mpg in the city with my 235 and 1 barrel carb. Just wondering what others are getting in comparison with the same size engine.
Mark | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I'm getting 15 but I have a 3.38 rear end | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just got back from a 1,000 mile trip in a '52, 3104 with the stock 216, 3sp, and 4.10 gear, the carb was a Carter W-1 however. We averaged about 16.5 mpg running most of the way at between 50-55mph. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I can usually get the mileage up to 13 or so if I do more freeway driving but the stop and go of city driving takes its toll. I'm wondering if I should switch to a higher octane gas. I keep the engine tuned pretty well. | | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Speaking of fuel...
Are you guys using additives with each tank. I'm not on the road yet but I'm thinking about what an engine designed for leaded fuel might need.
Thanks | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | 14 mpg in my mixed commute and 17 on the highway. GMC 270 with an SM420 and 3.08 gears.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | 19mpg in town.highway 22mpg.51 3100. 350cid,365hp.700r4 tranny,Ford 9" rear end 3.33 gears.
dan-pa
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Mark, you should be getting better than that with the '57. You didn't mention what transmission or rear-end gear you have in it, but if it's completely stock and the engine isn't worn out, 16-18 is a realistic figure.
As for using high octane fuel helping with your milage, no, it isn't going to change that, just cost you more for fuel. The compression ratio of an engine is the determining factor as to what octane rated fuel to run. The higher octane fuel is meant for high compression, high performance engines, your 235 should run just fine on regular.
Needing to use the lead substitute additives as a valve lubricant is a myth. The TEL (tetraethyl lead) was added back around WWI as a cheap way to boost the ‘octane rating’ to prevent premature detonations. TEL made a lot of money for the investors in the Ethyl Corp. Octane contains 8 carbon atoms linked together, and it will spontaneously combust even at low compression ratios. An 87 octane rated fuel is 87% octane and 13% other blends like heptane or other fuels used to adjust the rating. This is more costly than simply adding TEL. Also Alcohol blends will also boosts the octane rating. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have a 54/3100 with a 2.73 rear end and T-5 trans and 2 rochester's , dual exhaust 15" tires and around town i get 12-14 and on the road i can get as high as 23.5 and averaged 20 on the trip to KC and back, 1100 miles running 70 mph.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Stop worrying about your engine and think about what kind of gearing you have.I am running a built 350 tied to a 700R4 overdrive tranny.then into a stock 3:90 rearend. I get 20 MPG all day long,because of the OD tranny.And with that wicked low gear in the 700R4 it will blow the doors off of most cars that wanna drag race with me.Way too many people are looking for good performance and fuel economy,without looking at how they are geared.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | The mileage is only important if you drive many miles. I just enjoy the drive and forget the mpg. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Hey: Don't feel to bad, my 235 in my 2 ton must get about 5 MPG if I,m lucky. I have to buy gas allmost every time I take it out! | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | This past weekend I got 15 1/2 combo hwy/city. have a 261 .060 over with a howard m4f cam and a holley /weber 2bl carb from Tom Langdon, also a 3.90 rear end.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The factor determining fuel use is how many times a piston goes up and down in one mile. Every other time it takes in a mixture of one part fuel to fifteen parts air so the more times it goes up and down the more fuel it will use. The ONLY way to slow the piston cycles down is through gearing. That's the physics, but in the real world gearing can be too shallow which leads to an open throttle/low manifold vacuum condition that uses fuel, tire type and inflation, wheel alignment(front and rear), increased friction like brakes dragging and dry or tight/loose bearings, engine temp too low, carb not adjusted correctly, state of tune, free flowing exhaust but NOT large diameter pipes, and the most important factor IS THE DRIVER. Our shop truck goes through a tank every two days with one driver and every three days with the other.
Evan
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I get 16 mpg in my 1 Ton, empty or loaded, my commute is mostly around 25-35 MPH. I have stock (5.14) gears in the back end, and big bias ply tires. I like the low gears in the back, as I can shift into 4th at 20 mph.
In my opinion, if you are driving in the city, the only way you are going to increase the mileage you get, is to drive with a light foot. At the same RPM, you burn more gas with your foot to the floor, than with it closer to idle. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I got 16 mpg with my 55 2nd with the 235 3 speed and original rear end.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2010 Posts: 60 New Guy | | New Guy Joined: Jan 2010 Posts: 60 | Talking about Gas mileage.
Has anyone seen a higher or lower mileage after changing from a 216 to a 235 in their vehicle ? By the way you are lucky with the gas prices in the States here it cost more as $ 8 per gallon. Thank you
Jianis
| | | | | Joined: Dec 2009 Posts: 42 'Bolter | | 'Bolter Joined: Dec 2009 Posts: 42 | 56 3100, not stock 305/turbo 350 with stock rear end, i think 390 gears, 10mpg on hi way, 12mpg in town
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | A side note. waited until today to fill up and gas has gone 20 cents a gallon in two days.
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | When I installed the T-5 and modern rear end behind the 235 in my 37 the gas mileage got worse,those motors are not designed to spin so slow with the original carb so I have been tweeking the carb some and got it better but the 2.79 gears are too tall so I am going to install 3.50 gears and continue the tuning. I put in a smaller jet and lighter power valve spring but I think the power valve spring is not light enough. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i never much checked the MPG until i had it finished and i have a t-5 with 2.73 rearend and i have wondered if a higher ratio would help especially around town, let me know how it works out. ron
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | '53 6100-2spd rear-6.10/8.13-235-4 spd trans. 8-9 mpg, 0-60 never going to happen  | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | 0-60 never going to happen  Mom bought a bug when she wrecked her 67 Olds to get her by til it was fixed. I remember her saying every time we took off "0-60 sometime today" Of course after getting it to 60 it ran great. | | |
