0 members (), 231 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
Hello,
I am having a really hard time getting my old 216 out of my 1946 Chevy Stylemaster Sedan. The confusion began when it came time to separate the engine from the transmission. I got the clutch bolts off no problem, got the bottom two trans bolts off no problem; one of the upper trans bots is against the firewall and the other isn't even visible. Whats the trick to getting this motor out. I don't have to pull the transmission and the engine together do I. Its a 216 stovebolt mated to a 3 speed column shifted trans.
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder
1971 Chevelle SS
1995 Monte Carlo Z34
2005 Corvette Z51
The only way is to pull the center floor pan to have access to the top trans bolts.
If you lift the floor mat you will see.
My Blog
Got it, thanks,
one more question. When I am installing the new clutch, how do I get it lined up properly. I don't have one of those plastic tools?
DG
1971 Chevelle SS
2005 Corvette Z51
They are sold cheap everywhere $5 buy one!
Thanks guys, engine is out.
I had a little problem with the clutch and linkage. I unbolted the clutch from underneath the car, and when pulled the engine out it feel out of the car. Thankfully i have another.
DG
1971 Chevelle SS
2005 Corvette Z51
Does anyone know if I can use my old oil canister? I had a 46 216 and now the motor is a 54 pressurized 235.
DG
1971 Chevelle SS
2005 Corvette Z51
As long as your old oil canister is the style that has two oil lines (hoses), you may use it on a high-pressure 235.
