| | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Hello,
I am having a really hard time getting my old 216 out of my 1946 Chevy Stylemaster Sedan. The confusion began when it came time to separate the engine from the transmission. I got the clutch bolts off no problem, got the bottom two trans bolts off no problem; one of the upper trans bots is against the firewall and the other isn't even visible. Whats the trick to getting this motor out. I don't have to pull the transmission and the engine together do I. Its a 216 stovebolt mated to a 3 speed column shifted trans.
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder 1971 Chevelle SS 1995 Monte Carlo Z34 2005 Corvette Z51
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The only way is to pull the center floor pan to have access to the top trans bolts. If you lift the floor mat you will see.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Got it, thanks,
one more question. When I am installing the new clutch, how do I get it lined up properly. I don't have one of those plastic tools?
DG
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are sold cheap everywhere $5 buy one! | | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Thanks guys, engine is out.
I had a little problem with the clutch and linkage. I unbolted the clutch from underneath the car, and when pulled the engine out it feel out of the car. Thankfully i have another.
DG
| | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Does anyone know if I can use my old oil canister? I had a 46 216 and now the motor is a 54 pressurized 235.
DG
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As long as your old oil canister is the style that has two oil lines (hoses), you may use it on a high-pressure 235.
