4 members (2-Ton, treegrower, Phak1, KEVINSKI), 90 guests, and 2 robots.
Topics128,196
Posts1,057,395
Members48,471
I have a 57 gmc w/347 Pontiac, has original 3 speed, want to buy a 4 speed, anyone know if anything (4 speed) will bolt up to the stock bellhousing ?
Need trans & shifter too !
thanks
Any small index GM 4 speed (exept for the late '60s Pontiac "Dearborn" 4 speed) will work fine. The SM420, which was the factory option on the '57 GMC is a direct bolt in, no additional linkage required.
Bill Burmeister
Cool Truck Jeff! Longbox already answered your question but I just had to give you a couple thumbs_up thumbs_up
I like the Pontiac striping on the rear fenders.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks, now if I can find one !!!
Normally I wouldn't reccomend a T5 with a v8, but your 347 is only good for about 205 HP. A t5 would give you OD, as would an A833. The A833 will require some machining of the bearing retainer to fit the bellhousing. For what it's worth, I have a NV4500 behind my 1959 Pontiac 389, bored and stroked to 447, in my 1959 gmc 1/2 ton.
Transmission reccomendations are hard to do without knowing how you plan to use your truck.
