| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | I have a 57 gmc w/347 Pontiac, has original 3 speed, want to buy a 4 speed, anyone know if anything (4 speed) will bolt up to the stock bellhousing ? Need trans & shifter too ! thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any small index GM 4 speed (exept for the late '60s Pontiac "Dearborn" 4 speed) will work fine. The SM420, which was the factory option on the '57 GMC is a direct bolt in, no additional linkage required.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Cool Truck Jeff! Longbox already answered your question but I just had to give you a couple I like the Pontiac striping on the rear fenders. | | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | Thanks, now if I can find one !!! | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Normally I wouldn't reccomend a T5 with a v8, but your 347 is only good for about 205 HP. A t5 would give you OD, as would an A833. The A833 will require some machining of the bearing retainer to fit the bellhousing. For what it's worth, I have a NV4500 behind my 1959 Pontiac 389, bored and stroked to 447, in my 1959 gmc 1/2 ton.
Transmission reccomendations are hard to do without knowing how you plan to use your truck. | | |
