1 members (Otto Skorzeny),
85
Mod | | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I parked my '55 1st GMC Suburban in March and was not able to drive it again before yesterday for health reasons. It was parked inside and was started and allowed to reach operating temperature about a month ago, but wasn't moved.
Yesterday when I went to move it, I get grinding trying to put it into any gear. I finally shut it off and started it first in reverse, and the repeated the process in 1st to move the truck.
I pushed the clutch all the way in and and let it out many times, with varying degrees of violence. It stayed stuck.
Any suggestions how I free up my stuck clutch?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | take off the flywheel cover and loosen the pressure plate bolts. Then see if you can't tap a thin blade putty knive up behind/frt of the clutch without damaging it. Its worked for me on some vehicles in the past. | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | try using a tractor and a chain, worked for me. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Its kind of common for clutches to rust to the flywheel in high humidity. We had about a dozen Cummins pullout engines in a storage trailer last winter which was the wetest winter I can ever remember. I think every one rusted the clutch to the flywheel. Of course its not a big deal with an engine on a stand. I got one unstuck years ago by putting a broomstick on the clutch pedal to hold it down and then I took the bottom cover off and hit the disc with a center punch in the gap between the linings. Hope something like that works so you don't have to pull the transmission. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | It happened to me... I started it in gear like you, gave it some gas with the clutch pushed in, and it finally freed up. I think I put the load on the clutch both ways... Ie Gas and coasting. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | This used to happen on my Ford 1715 tractor all the time but it always broke free at WOT in neutral and working the clutch pedal. Now my little Farmall Cub has the same issue and I can't get it to free up even by pulling against a large tractor. Sure hope I don't have to break the tractor in two. Must be common problem. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Thanks for the ideas guys. Tomorrow I should have time to try some of them...
I'll report back.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | heres what I did when mine stuck, lift the rearend off the ground, its best to place jackstands under it, start the engine, transmission in gear, clutch pushed in, lock the brakes several times. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | steve i know your pain! my 53' ford NAA has this issue and i broke the clutch loose 3-4 times loading and unloading it but this time were gonna have to split the case. sure am glad the forklift is running as that will make the job a little easier. hope your feeling better dude! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | it always broke free at WOT in neutral Being the least invasive I tried this approach first. And it worked! Thanks for the suggestion! I suspect I'll be replacing the clutch someday in the not too distant future, but my plan is to replace it with a torque converter and automatic trans. My health problems are making clutches hard to deal with.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Steve, good to see that your back to playing with trucks....
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Glad to hear that it worked as easily as it did. I wouldn't be so quick to through out the standard unless you just like auto trans. In a year from now you might want to put the standard back in. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I've placed a steel rod in such a way that it holds the clutch disengaged while it's sitting unused. I was told this works but I'll know for sure in a few months when I finally get this thing moving under its own power. | | |
