5 members (Shade Baby, Phak1, klhansen, Otto Skorzeny, BC59), 139 guests, and 1 robot.
Topics128,041
Posts1,055,483
Members48,424
#678730 09/19/2010 12:44 AM
Can I use rubber flexible fuel line from my in-cab fuel tank to my engine's fuel pump? It's got the old steel line thats all rotted out. I'd rather use rubber if it's safe.
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
There is rubber hose available for gas lines. One of my vehicles has rubber lines, but short ones, and the other one I made out of a 25ft coil of steel lines so it would be one continous line from the back of the panel to the fuel pump.... but in all honesty I'd run metal. Heck, I think metal is even less costly than the rubber which is priced by the foot!!
I'm in the process of removing the all rubber run on my '56 and replacing with metal. I had fuel delivery problems on the road to KC and back and I suspect the old hose is collapsing. The problem doesn't surface going to local shows and stuff but get her out on the highway for a few hours and it starts to close up.
The reason I ask is that I've got a bunch of ethanol resistant fuel line that I can use, rather than buying more steel line...
I am with Cletis: metal beats rubber. Rubber can provide help/safety in places that have movement/vibrations (as in brake hoses in key spots). I am using rubber in the last 12"-24" of fuel lines (and an in-line fuel filter) in a dual-carb set-up, but I know I should change to metal.
use the rubber if you have, and if it starts to give you problems later on, change it out
Redryder pix
My Hotrod
the only rubber i use is the little short pieces that come with the inline filters. i mount the filter as close as to the tank i can with access to change it with the least amount of mess. from there its steel all the way to the carb.
