| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | Can I use rubber flexible fuel line from my in-cab fuel tank to my engine's fuel pump? It's got the old steel line thats all rotted out. I'd rather use rubber if it's safe.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | There is rubber hose available for gas lines. One of my vehicles has rubber lines, but short ones, and the other one I made out of a 25ft coil of steel lines so it would be one continous line from the back of the panel to the fuel pump.... but in all honesty I'd run metal. Heck, I think metal is even less costly than the rubber which is priced by the foot!! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm in the process of removing the all rubber run on my '56 and replacing with metal. I had fuel delivery problems on the road to KC and back and I suspect the old hose is collapsing. The problem doesn't surface going to local shows and stuff but get her out on the highway for a few hours and it starts to close up. | | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | The reason I ask is that I've got a bunch of ethanol resistant fuel line that I can use, rather than buying more steel line... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am with Cletis: metal beats rubber. Rubber can provide help/safety in places that have movement/vibrations (as in brake hoses in key spots). I am using rubber in the last 12"-24" of fuel lines (and an in-line fuel filter) in a dual-carb set-up, but I know I should change to metal.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | use the rubber if you have, and if it starts to give you problems later on, change it out Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | the only rubber i use is the little short pieces that come with the inline filters. i mount the filter as close as to the tank i can with access to change it with the least amount of mess. from there its steel all the way to the carb. | | |
