7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hey guys, so I just got my truck, and it has a rather unpleasant odour in the cab...smells like urine, yeah, pretty gross. I thought it was the floor, until I realized that after sitting in it, my jacket smelled like the truck. So it's the seat.
My question is, will shampooing the seat eliminate this? If not, what else can I do? The seat is in beautiful original shape, not a tear or stain anywhere...so I'd really like to save it!
The truck sat for 3 years before I got it, so I'm guessing it's mouse pee. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | You could take it apart and wash the foam and padding and put it back together. If it is mouse pee they may have nested in the foam. You should be able to tell from the back side. If you don't want to take it apart, shampoo it and try some charcoal under the seat. Airing it out will help but smells tend to return on really hot days, in a closed up cab. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Put it out for a few days in the sun and let it air out.
~Jim
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | DADS50, yeah, I have driven it. It rides super nice, but runs only ok. Carburetor is goobered, will have to rebuild that, and then it should run good. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You'll most likely have to have the seat re-padded & re-covered. Urine smell is very difficult to get rid of.
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Such a shame. Really, you guys should see this seat! | | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | Junk the stinkin mess and replace it, every time the temperature gets up the smell will come back.  | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Simplest fix from my vantage point would be to get an upholstery kit from one of the vendors rather than try to save the old stuff. They are really quite inexpensive and come with all new stuffing. Anything that’s nearly a half-century-old is probably due for some new dressing any way.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Ok. I'm prettty convinced now that I need to get rid of the seat. I'll clean it the best I can and use some germicidal cleaner on it for now, and get an upholstry kit for it in the near future. Thanks for all the advice guys. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | An old prank was to raise the rear motor hood of the VW Beatle and pee on the heater tubing. When you cranked it up and it got hot you could smell burnt urine and it never stops smelling. Replace the guts of the seat and forget it.
~Jim
| | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | Adam61- So i have a similar situation. I just got a 52 chevy 1/2 ton. Turns out at some point, some cute little mice decided to nest underneath the seat. I've got some time as a detailer so i've treated similar oder's in other vehicles. in this case, i vacuumed everything out, treated the metal under the seat and re-painted. i can still smell it. Although i see people recommend fabreeze or other industrial cleaners, my advice would be to recover the seat. take it down to the frame and start over. quite frankly, no matter what chemical you use, padding is so thick and there is so much overall material on seats, i doubt you could really clean it enough to completely remove the oder. plus chemicals that are too harsh will most likely damage the fabric....
Do something! Even if it's wrong!
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I would replace everything but the metal.
You can mask this problem for a period of time but it will return.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I would replace everything but the metal.
You can mask this problem for a period of time but it will return. I'll say it again......... Germicidal CleanerNot only does it kill those harmful/hazardous little bugs but it also neutralizes the bad smells. My bus had a foot of Rat Poop in it along w/who know how many years of being pee'd in. After cleaning it out and using bleach, baking soda & a bunch other things to get rid of the smell, I still could not put it in my garage for the next year, stunk to high heaven. I mixed up 1-2gallons of Germicidal Cleaner sprayed down the complete interior & in a matter on minutes the smell was gone for good  . | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I would also paint the metal frame as well and the floorboard under it.
~Jim
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Find a stock tank and fill it with laundry detergent/water and bleach mix (not too much bleach), and submerge the seat for an afternoon. Get the water as warm (hot preferably) as you can. Then rinse the seat real good with hot water after wards. Then set it out in the sun to drip dry for a few days and/or run a fan on it to help it dry. Clean the inside of the truck real good with hot water/bleach mix. Place a bar of Irish spring in the truck under the seat when you reinstall it. Make sure the seat is fully dry before you put it back in. | | |
