7 members (Steelonsteel, J Lucas, Wayne67vert, Shade Baby, rfs56trk, greenie-reddy, 1 invisible), 79 guests, and 4 robots.
Topics128,269
Posts1,058,399
Members48,485
#678690 09/18/2010 9:57 PM
My steering box on my 46 1/2 ton is tight with no play in it,but the seal was leaking. I took it apart cleaned the gunk out of it ,and I am going back with a new seal and gaskets.My question is what should I pack the bearings with grease then put gear oil in it ?Or is there somthing better to use?I have heard some guys using nothing but grease.
Thanks for your help
Longhorn
Longhorn, I use Cornhead grease in mine and it's working good no leaks and streers well.It's made for John Deer so You can get some at one there dealers.
Pete
I used the same 80 weight oil that I put in the transmission, works fine. Don’t forget there is no seal at the top around the steering wheel shaft. If you over fill the lube can actually come out at the steering wheel
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
The OE specs call for a self leveling grease. The closest thing today is the John Deere corn head grease that Pete mentioned above.
Thanks guys
I have a John Deere dealer close to me .I will get some corn head grease and use it.
Longhorn
Any grease with a 0 or 00 grade will work. These are the self leveling greases. I am using a 00 grade synthetic I bought from a grease vender at work. Even a normal grade chassis grease will work with a 50% gear oil mixed in. If the pitman shaft is good and tight and the seal works as it should, straight gear oil will work. The John Deere grease is sold at the big tractor dealers, not lawn and garden shops.
Joe
