0 members (), 99 guests, and 2 robots.
Topics128,049
Posts1,055,741
#67844 10/26/2006 11:11 PM
I did a search for U-joint Lubeing and did not get anything so here is my question....
How do you lubricate the U-Joint in the enclosed driveshaft??(54' 3100)
When you lubricate the U-joint...what lube do you use ??
1954 Chevrolet 3100
235 c.i.
3 speed on the column
Mariner Blue
Pearl beige
#67845 10/26/2006 11:36 PM
As per the 49-51 shop manual: "Remove square head pipe plug from rear of transmission case, lubricate the universal joint and propeller shaft bushings by inserting 1/2 pint of lubricant thru the opening and replace pipe plug." Use the same 90 wt. gear oil that's in your tranny.
Curt B.
You Tube
#67846 10/27/2006 1:33 AM
Yep, my replacement U-joint came today and had a warning to not use grease, but 90W tranny fluid only...
#67847 10/28/2006 10:30 PM
After I had my 52 for a couple of months the u-joint went out. After I replaced the u-joint I lubed with 90 weight gear lube via the square plug in the rear of the tranny. A pint is good, a quart is better mentality prevailed. After filling the tranny, I decided to check the rear end, and gear lube poured out. So note to self follow the manual. Ya don't need more than a cup or so to lube u-joimt. Jimmie.
