| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67844 10/26/2006 11:11 PM | Joined: Jan 2006 Posts: 16 New Guy | | New Guy Joined: Jan 2006 Posts: 16 | I did a search for U-joint Lubeing and did not get anything so here is my question....
How do you lubricate the U-Joint in the enclosed driveshaft??(54' 3100)
When you lubricate the U-joint...what lube do you use ??
Thanks | | |
#67845 10/26/2006 11:36 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | As per the 49-51 shop manual: "Remove square head pipe plug from rear of transmission case, lubricate the universal joint and propeller shaft bushings by inserting 1/2 pint of lubricant thru the opening and replace pipe plug." Use the same 90 wt. gear oil that's in your tranny.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#67846 10/27/2006 1:33 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Yep, my replacement U-joint came today and had a warning to not use grease, but 90W tranny fluid only... | | |
#67847 10/28/2006 10:30 PM | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | After I had my 52 for a couple of months the u-joint went out. After I replaced the u-joint I lubed with 90 weight gear lube via the square plug in the rear of the tranny. A pint is good, a quart is better mentality prevailed. After filling the tranny, I decided to check the rear end, and gear lube poured out. So note to self follow the manual. Ya don't need more than a cup or so to lube u-joimt. Jimmie. | | |
