6 members (Gdads51, MickeyP, 50Chevy3100, HandyAndy, Joe H, 1 invisible), 68 guests, and 1 robot.
Topics128,090
Posts1,056,015
Members48,430
I know that I have seen this before, but searching it out I cannot find anything relevant. I put disc brakes on my 52 and was planning on trying to put a master/booster in. Either under the floor or through the dash. The under the floor I keep hearing cannot be done with the stock transmission and that the clutch gets in the way. I thought I found a thread on this before.
Then I was looking at using a donor through the wall brake pedal and found that the location and the steering column is in the way. I see that they make a through the column mount, but the price is a bit high was wondering if anyone has come up with some other solution.
Engine 216 Stock manual transmission truck was a 1 ton is now a 1/2 ton. BTW I have some weird looking canisters under the cab beneath the passenger seat, could be a pump of some sort. Any one know what it was on a 1 ton? Thank you
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
What I have seen done is to move the booster & master cylinder back & extend the rod that comes off the stock pedal assembly to the booster/mc. I'm trying to find a pic of this set up...joe
They're are kits available that place the m/c about a foot away from the pedal assembly as Joe(Zookeeper) mentions,but as yet,I haven't seen one for an AD truck.
I'm running an auto trans so haven't had to deal with this problem.
Here's one i've seen for an earlier Chevy,I'm not sure if it could be adapted to fit.
It will give you the general idea though.
More pix on Flickr.
I was thinking about the longer shaft idea, but a friend of mine said that I needed to be concerned that it might create some angles going in and out. The firewall mount is the other one that has me baffled I was actually thinking of taking the foot brake and by welding on another box to the mount to the wall put a long screw that can turn when the pedal is pushed doing what it does now but along side the current setup.
Ok I can visualize it haha.
Engineered Components Inc. in Connecticut makes the bracket assembly that you are looking for to put the Master Cylinder/Booster under the floor.
Someone used a hydraulic clutch I believe. The archives here should help.
~Jim
It is interesting that you say that, I went under the truck today, I seem to be spending a lot of time down there recently and all I saw was the brake setup. There was a lot of room under there by the brakes and I could not find anything but a flex line that went to my manual transmission. I moved that line around and it flexed all over the place. I am just wondering since it was a 1 Ton truck originally would that make a difference, being that it is a 4 speed vs the 1/2 ton 3 speed? Will this make the job easier and do I need all the fancy setups or can I just install a standard under the floor setup. Thoughts?
The one thing that seemed to be getting close to being in the way was the parking brake line.
I have this kit:
http://www.classicparts.com/1947-54-Power-Brake-Booster-Conversion-Drum_Drum/productinfo/71-903/
It installed ok, works fine with the clutch and everything... My issue is the transmission cross member. The master cylinder goes through the cross member. I am not sure if anyone else has done this but I modified the cross member to allow for room. I will see if I can get a pic up for you to look at.
I don't know about you guys, but keeping the stock pedal/feel is what I really wanted out of my truck.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/
Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time.
Yes, I had the same prolem as TXChevy50. I modified my crossmember and welded a little extra under it... but I didn't need to as when I modified it I found out the crossover had a piece of 1/4's steel bar through it but not all crossmembers are like this. Here are a few pics. Hope they help.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/trannymountectect011.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Crossmembercutout003.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Crossmembercutout004.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Crossmembercutout001.jpg
It has been a while since I posted, well since I worked on the truck either, but last night installed the Master Cylinder and booster and it was pretty much a plug and play situation. Did not need to modify anything other than drill 3 holes. I was amazed how well it went into place I thought it would be a nightmare and it turned out to be probably the easiest retrofit that I have done.
Although the setup was bought from American Classic Truck Parts it actually was dropped shipped from CPP. I have to say I am extremely pleased that I did not need to modify anything this time around. Now I just need to run the lines and I should have brakes again.
MC and booster install is a major discussion item here, What truck did you put it in. How about some pictures?
~Jim
....if I remember correctly Jackyl converted a 1952 one ton to a 1/2 ton. If thats the case the hole for the m/c were probably different than my 52panel. I used m/c-booster from PirateJack out of Asheville, N.C. and it was a direct bolt in. All the stuff I needed at a good price and I didn't have to drill one hole. I did have to cut the brake pedal hole out about 1/4' at the top....and as I said above I had to modify my crossmember but maybe that was just because of the crossmember itself and not because of the choice of systems?
Jackyl, be sure and bench bleed the m/c real good because sometimes they can be a pain to get all the air out!
That is correct it was a 52 1 ton that is now cut down to a 1/2 ton. I could not be more pleased with the install. I have it test fitted now, but plan on pulling it all out again to bleed it and get everything going.
Just having brakes again will make me happy considering now it is very hard to stop when I back it out of the garage.
...rather than pull it out to bleed make you up a couple short plastic lines and just turn the ends back into the reservoir. Its a lot simplier/easier than pulling it back out and you can keep and reuse the lines on something else..... I actually had some metal lines that I curved right back into the m/c.
Just and idea.
Can you use that set up if you are running headers and a v 8 chevy 700 r 4 combo????
Probably not, I am using a stock setup. The only difference I have is that I do not have 3 on the column but a 4 speed on the floor because it was a 1 ton.
Plus I do not have any transmission supports in the way. The only issue I have is the speedo cable and that is flexible.
Superfly, what truck chassis are you using? Not that it makes any difference but it might??
I'm running headers on my 350 with 700R4 in my 37 pickup with original chassis with no problems. I have not run the exhaust on my panel yet but I'm using a set of ram horn 283 hearders on it but I believer a set of headers would be low enough to work on the 52 panel.....someone else may be able to answer your question better than me.
Sliding under my truck during mock up, i quickly realized that there is no room for brakes and exhaust beside the transmission. The long tube headers take up way too much room. I dont want to mount the master on the firewall (for looks) so I am looking at a 90 deg under dash master cylinder and brake booster. Has anyone used one and if so who's do you recommend?
1950 GMC 3100
Camaro frt clip, 4 link, 6.0L, 4L65-E
More pix on Photobucket
Have you considered moving the master back behind the trans?
No Limit Engineering has a kit.
Or you could fab it up yourself.
Regards,
Leon
Good topic
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
