3 members (TUTS 59, greenie-reddy, Youngin' Tut 59), 56 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#67803 10/26/2006 12:46 AM
Hi Stovebolters,
Thank you for your help with my question about 12 v and 6 v starting on my '51 3604. Tomorrow I attempt the spin and start. My next question involves the rusty insides of the gas tank for my '63 chevy C20. I'm sure the answers will apply to my '51 tank as well, which is also rusty. The guy who boils tanks says the '63 tank is too big. Is muriatic acid the only solution? 15 gallons of gas was brown. The fuel gauge sensor came out rusty --- is that cleanable, or toss it? The engine runs fine off gas can. Any tips on this are appreciated, (btw --- I don't expect to achieve novice-grade stovebolterhood until I revive that 216!) grin
#67804 10/26/2006 1:31 AM
I used the POR-15 tank cleaner and sealer kit on my 48 and it worked like a charm. The tank was pretty bad inside. I was getting a lot of crud in my fuel filter. No problems now.
I've also read that some folks put some old nut's and bolts inside the tank after removal and shake the hell out of it for 10 minutes or so to loosen up the years of varnish and debris.
-Rich
#67805 10/26/2006 3:24 AM
Buy a new one if you can afford it, eliminate potential problems with a fresh fuel system,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#67806 10/26/2006 10:46 PM
Ex Hall Monitor
Ex Hall Monitor
POR-15 tank cleaner and others like it are simply phosphoric acid. Muratic acid is more dangerous but a lot cheaper. If you use muratic acid dump a few gallons of soda water in to kill the acid before you dump it out. You'll then need to use a tank coating like Redkote or Kreem on the inside or your tank will rust. If your sending unit works use it. Clean the rust the best you can before you put it back in.
#67807 10/27/2006 2:03 AM
I poured in about 2 coffee cans of nuts and bolts and a few gallons of diesel. Made a couple of plugs for the gas tanks and rolled her around the yard about 100 times. Knocks most of the stuff loose. Also I used a drill pump and a lot of rag filters for recirculating the diesel through to clean it all out. Then When I thought I got it all I used a shop vac with a custom piece of pvc to scrape the bottom and clean her out as best I could.
I also cleaned a ton of rust off my sending unit and she works great now.
good luck and let us know! Jeff
My 1953 Chevrolet
1947.1 Gallery
