| | | Forums66 Topics128,168 Posts1,057,098 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 23 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 23 | I know cab an interior parts will interchange ...but will grille parts such as lower grille support from 1/2 ton fit on to a big bolt....dont wanna spend the money for something that wont fit
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | it'll have to be confirmed but I do think the Big bolts are different....I'm almost positive since the fenders and hood are different. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | big bolts are wider, look around for a 1/2 to 1 ton, good luck and welcome to the bolt | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Basically, everything from the firewall forward is different on the 1.5 and larger trucks to accommondate for the bigger tires(hood, inner and outer fenders, grill, horizontal grill supports, splash apron bumper, etc...). Those parts are not available new from any vendor. I've been fortunate so far locating certain parts on here in the parts wanted section. Good luck! | | |
