0 members (), 151 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
I built a pressure bleeder last weekend using a garden sprayer from the hardware store. Kind of crude but it got my firetruck on the road again. A bit messy taking it off with the adapter I made out of an old master cylinder cap. Curious what others have done. Thanks Don
I like the mighty vac hand bleeder ,Built my own in the past but just faster and less time to buy it .
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
I have an Aamco "Pig" pressure bleeder, cost, $0. Still need to make an adapter to fit my master cylinder. I use a Master Products presure bleeder at work (my own tool, not owned by the shop).
Bill Burmeister
I cheat, I use a BG brake fluid flush machine from work. It pumps fluid in through the master and sucks it from the bleeders. No mess what so ever!
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I now have a Branick pressure bleeder http://www.branick.com/core/products_brake_bleeder.php. I actually bought it to bleed my fork lifts, but it gets used more on my jalopies. My pressure bleeder of 50 years ago was a Master cylinder cap with a tubeless valve stem in it and a Golden Rod Bicycle pump. The bad part was one pump and I had to take the cap off and add more fluid. But it was portable enough to carry along on a cabover International to bleed the hydraulic clutch.
Found the skinny on home brew bleeder, this is great and almost free it's so cheap.
http://www.bmw-m.net/TechProc/bleeder.htm
1946 1/2-Ton Chevy
Moderated by  MNSmith
