| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I built a pressure bleeder last weekend using a garden sprayer from the hardware store. Kind of crude but it got my firetruck on the road again. A bit messy taking it off with the adapter I made out of an old master cylinder cap. Curious what others have done. Thanks Don | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I like the mighty vac hand bleeder ,Built my own in the past but just faster and less time to buy it . | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have an Aamco "Pig" pressure bleeder, cost, $0. Still need to make an adapter to fit my master cylinder. I use a Master Products presure bleeder at work (my own tool, not owned by the shop).
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I cheat, I use a BG brake fluid flush machine from work. It pumps fluid in through the master and sucks it from the bleeders. No mess what so ever! Scott | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I now have a Branick pressure bleeder http://www.branick.com/core/products_brake_bleeder.php. I actually bought it to bleed my fork lifts, but it gets used more on my jalopies. My pressure bleeder of 50 years ago was a Master cylinder cap with a tubeless valve stem in it and a Golden Rod Bicycle pump. The bad part was one pump and I had to take the cap off and add more fluid. But it was portable enough to carry along on a cabover International to bleed the hydraulic clutch. | | |
