1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#676121 09/07/2010 4:19 AM
Looks like my original glass is separating causing splotches on the edges of the glass. I know it is unavoidable, but is there a way to repair this? If not, then my vent window glass needs to be replaced. Is it hard to remove the vent window glass? (not complete frame assembly)
1958 Apache Shortbed Fleetside
no, fogging or delamination aren't repairable - changing the glass is a piece of cake for a glass shop if you take it to them, preferably the removed assembly
As an add on to Bills answer, once delamination has occurred the glass becomes very brittle and is easier to crack,due to the separation.
More pix on Flickr.
....if you can get the wing vent glass out easy I would say replace it with the assembly still in the door......just my .02 cents. Fill the glass frame with Black ADHESIVE silicone. Cut the tube so it will put out a big enough line to fill the vent window frame. Then slide in the new glass, close window and pull the glass back a little so its a tight fit, then lock the window in place until the next day. Then trim off the excess and see what a good job you have done.
Don't even try to mess with the black mess until after its dried or you will have a mess. It will Scrape off the glass easy.
