| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Looks like my original glass is separating causing splotches on the edges of the glass. I know it is unavoidable, but is there a way to repair this? If not, then my vent window glass needs to be replaced. Is it hard to remove the vent window glass? (not complete frame assembly)
1958 Apache Shortbed Fleetside
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no, fogging or delamination aren't repairable - changing the glass is a piece of cake for a glass shop if you take it to them, preferably the removed assembly
Bill | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | As an add on to Bills answer, once delamination has occurred the glass becomes very brittle and is easier to crack,due to the separation. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....if you can get the wing vent glass out easy I would say replace it with the assembly still in the door......just my .02 cents. Fill the glass frame with Black ADHESIVE silicone. Cut the tube so it will put out a big enough line to fill the vent window frame. Then slide in the new glass, close window and pull the glass back a little so its a tight fit, then lock the window in place until the next day. Then trim off the excess and see what a good job you have done. Don't even try to mess with the black mess until after its dried or you will have a mess. It will Scrape off the glass easy. | | |
