| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 25 New Guy | | New Guy Joined: Apr 2009 Posts: 25 | Checked all the usual sources for window regulator plastic rollers for my 49 pickup with no luck. Dorman makes rollers but I did not find a way to size them. Would appreciate some advise.
Thanks, Dale | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | There are three shown in the Filling Station catalog. 3/16" shaft 1/4" shaft 5/16" shaft
| | | | | Joined: Apr 2009 Posts: 25 New Guy | | New Guy Joined: Apr 2009 Posts: 25 | Tiny
Thank you, I will give them a call.
Dale | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | just be sure you get/have the right ones before you drill/grind yours out......in case you have to grind yours off smooth and drill a hole the size of the "pin". Don't ask how I know....not enough room here to tell you!! | | |
