2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#674439 08/31/2010 4:56 PM
JFO
Offline
I have seen some threads discuss how difficult or impossible it is to find replacement rims for the 3600. One forum suggested the 8 Lug F truck 250 stock wheels would fit. Does anyone know if these rims will fit and clear the steering links? I have searched for replacements but unable to find the backspace on suggested replacement rims.
JFO #674458 08/31/2010 7:08 PM
They do not clear the originals. I used 1990-91 Suburban 3/4-ton wheels on my truck(which also do not clear) and tried them to see. I ended up modifying my steering arms and going to a custom tie-rod but I wanted to run tubeless and radials so the modifications were not and issue. I did get them to accept wheel hub cap clips and original caps and they look very good now to me.
I switched over to Dexstar trailer rims. They work fine on the rear but when turned to the extreme on the front they rubbed on the tie rod ends. I swapped over to the 1 ton tie rod/tie rod end setup and gained more than enough clearance. Auto Zone can still order new (made in USA) ends and NOS tie rods are plentiful.
I did some measurements with flat boards spanning my aftermarket 16 in. one-piece rim. I come up with an inside bead width of 6 in. The inside mounting surface is setback 3 3/4 in. from the outside of the bead. These rims work with 235-85R16 tires (Michelin highway treads). One of the tire shops in town said they could order them so they should be available everywhere.
Also, if you search the forum way back on this topic, I gave the markings on these rims which might help.
