| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Hi there,
I swapped in a 1955 Car engine into my 1954 Chevy Truck. The old engine had a remote oil filter, the new one from the '55 doesn't appear to have the same connector.
Can anyone tell me if the '55 auto engine required a remote filter? I cannot find a filter space in that engine. I would think it would need one but I am a little confused as to where it would connect.
Thanks for the help.
Carlos | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A filter isn't necessarily required, as it was optional on the 6 cyliders, but if you want to use the one from your original '54, it hooks up the same way. You'll have to swap the pressure gauge connector for the T connector from the original engine.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks for the tip. If I don't run a filter, how often should I change the oil? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks. I'll likely leave it as is and be diligent about changing the oil. | | |
