8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible), 103 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
Hi there,
I swapped in a 1955 Car engine into my 1954 Chevy Truck. The old engine had a remote oil filter, the new one from the '55 doesn't appear to have the same connector.
Can anyone tell me if the '55 auto engine required a remote filter? I cannot find a filter space in that engine. I would think it would need one but I am a little confused as to where it would connect.
Thanks for the help.
Carlos
A filter isn't necessarily required, as it was optional on the 6 cyliders, but if you want to use the one from your original '54, it hooks up the same way. You'll have to swap the pressure gauge connector for the T connector from the original engine.
Bill Burmeister
Thanks for the tip. If I don't run a filter, how often should I change the oil?
The 1955 Car Owner's Manual states that engine oil should be changed every 2,000-3,000 miles and the filter (if equipped) should be changed every 6,000 miles.
Every 2,000 to 3,000 miles for truck engines, too.
Thanks. I'll likely leave it as is and be diligent about changing the oil.
