9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible), 75 guests, and 0 robots.
Topics128,205
Posts1,057,427
Members48,471
I
I Offline
I've got a Chevy 3100 that I'm finally getting back to working on, and the parking brake linkages I bought from what used to be Chevy Duty, at least at the time I bought them, has these two gold colored brackets that seem like they should clamp upon something with a pair of bolts. I'm utterly confused at what they're for and the linkages that these replaced didn't have them so it didn't really help me. Do they go inside the brake assembly or outside or? The linkages seem to hook up like they should except for this one part.
Thanks a bunch for helping out one who is still a beginner no matter how long it has taken me on this project... :p
Erik Berg
1952 Chevy 3100
A photo would sure help.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/304.HTM
Are you referring to the where each cable passes through the brake shoe backing plate to connect the brake shoe?
As Woody posted, words often fail but photos make it clear what parts you are referring to.
If you're trying to replace original equipment you need to get a factory assembly manual.
http://www.themotorbookstore.com/1947chevytruck.html
~Jim
MMMmmm, if you bought the emergency brake cable one end of it has a "bracket" that bolts to the back side of the backing plate and the other end will go to and through an "arm" that is riveted to the side of the chassis and has one bolt through it to hold it from moving....then the very end of the emergency brake cable will fasten to a "bracket" that goes on the outside end of the emergency brake cross member and a bolt goes throught that bracket to hold it to the crossmember while the cable is put through the bracket so you can adjust it....Whew!!
Like the other bolters suggest. Get a shop manual, or use the one on line, and also a factory assembly manual. Good luck.
