1 members (klhansen),
98
0
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67132 10/13/2006 8:56 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'm going to install a T5 in my 46 (216 bellhousing). I want to pull the torque tube and insert a pumpkin from a newer truck. Now I know that a 55-59 will bolt right up and I can use my original axels, keep the orig. brakes etc. But what about newer trucks, say 60-65. Will any of these work? Also I think that the 55-59s came stock with a 3.90 rearend. I would like to get something closer to a 3.73 or higher. I want to save my orig. rear axel and just bolt something up. Any suggestions? Thanks George | | |
#67133 10/13/2006 9:10 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd call Patricks and see is their sets fit your housing. Stock ratios are really low, so you'll have to step up to the new set of gears. I have a 65 pickup 3:08 under my 46, work's great and it was cheap. That later gear will not fit in your old housing! I'm using my stock bellhousing with an adaptor from Buffalo Ent for the T-5. We had 6 41-46 pickups at this years Lodi Picnic, 5 had gone to the T-5!!! | | |
#67134 10/13/2006 9:12 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | George,
I believe a 55-62 pumpkin will work. 3.90 was standard, though I think higher gears could be found in an automatic truck. | | |
#67135 10/13/2006 9:32 PM | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | George,
Have a good used 3.90 pumpkin out of my 58 if you decide to go that way.
Richard
Richard 58 3104
