2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67081 10/12/2006 1:47 AM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | has anybody ever done a diesel swap .. if not does any one have any info on whats the best motor to swap in to a stovebolt and such.. thankyou derek | | |
#67082 10/12/2006 12:11 PM | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | I like the sound of a detroit 6-71, but not many bolts have an engine big enough to accept that much engine.
Someone on this board is putting a detroit 4-53 in their "big bolt". It's looking like a slick setup. He custom fabbed mounts, and you'll have to make sure you have a front axle that can hold that weight.
I don't know if one of the cummins B series will fit or not. | | |
#67083 10/12/2006 5:33 PM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | i hope one day to do a turbo diesel that would be sick to throw a detroit diesel... also did chevy have a diesel engine out back in the 1950s i dont think sooo right b.c companys like cat and detroit where into that feild of production ? thankyou derek | | |
#67084 10/12/2006 9:10 PM | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Check out this link... to this site! http://www.stovebolt.com/gallery/stone_moe_1959.html Now THAT is a bolt. I belive that GM was the first to make the 2-stroke diesel and they sold the production rights to detroit diesel. I think I could fit a 4-53 or 3-71 in my engine bay, but I'd need to beef up the front axle a bit. Even then, I'm not sure it would out torque a well built 292, which will fit in with far less money and effort (from what I've read). That's what I'm thinking about for my rig. I've heard they are casting cross flow heads for the 235 / 261 and for the 250 / 292. I don't think they are available yet... but put a blower on a built 292 and you'll have to start strengthening other things to handle the torque. | | |
#67085 10/12/2006 10:28 PM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | wow thats a sick bolt... i want to do stacks at the very least to my chevy 3800 but yea diesel would be nice lol maybe ill jus work my stoc 235 .. ? | | |
#67086 10/12/2006 10:35 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I want to put a 6-71 in my 41 big truck. Its far enough gone (frame/running gear wise) Im gonna look for a 60s ish crackerbox and swap the cab onto it. Way to far in the future to think about... Detroits are some of the best made engines. They sleeve the cylinders so as long as you dont punch a hole in the block you can always rebuild em. | | |
#67087 10/12/2006 11:04 PM | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | A friend of mine was looking to swap a diesel out of one of those frito-lay cube trucks. Makes sense to me. A full load of potato chips must weigh.. what.. 300 pounds? High mileage, sure, but it probably never worked very hard.
-Joel
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
#67088 10/13/2006 12:32 PM | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Rustednuts,
Those crackerboxes were essentially cab overs. I've seen them for sale for about $2000 in "fair running" condition, but I don't know if you could fit a bolt cab over that frame. It'd be neat to sea though. They WILL last forever if you don't send a rod flying and maintian them well. I've heard they are tough to maintain though.
Joel,
I've heard those frito-lay trucks are the ones to get the detroits from for exactly the resason you mention... they've led an easy life. Did they have 4-53's?
I'm still thinking a 292 is the right thing for me. While I like diesel, I'd prefer a gasser 1 ton. If I ever got a 3 ton or so (like is in the for sale section right now) I'd definitely want a diesel. I'm thinking a 6-71 with 13 speed road ranger would be fun. | | |
#67089 10/13/2006 8:13 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I believe detroit had a 3 cyl diesal aluminum block in the 40's that was use in troup transports and 2 ton jeep trucks.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#67090 10/13/2006 9:16 PM | Joined: Nov 2000 Posts: 119 Member | | Member Joined: Nov 2000 Posts: 119 | The F-L trucks I have seen had 4-cyl Perkins engines. Have driven one with same. OK if you like extremely slow acceleration, a lot of noise and 55 mph top speed. | | |
#67091 10/14/2006 1:49 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A little info on the Detroits- Detroit Deisel was a division of GM, with design and testing of the 2 stroke engine stating around 1932, with production starting in '35. The original use for the engine was deisel locomotives. GMC offered it in trucks in '37/'38. Chevrolet didn't get a deisel until the '60s. Detroit Deisel engines were manufactured with both iron and aluminum blocks. They were also sold as Grey Marine engines for use in Navy vessels. The numbering system refers to the number of cyliders and the displacement of each cylinder, example-6-71= 6 cylider/71 cid per cylinder, 426 cid total displacement. These engines range from the 2-53 used in John Deere 420/430 to 12-110s that are usually found attached to hospital generators. This is also where the numbering for the aftermarket superchargers came from, as many early rodders used blowers from these engines.
Bill Burmeister | | |
#67092 10/14/2006 4:33 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thats really interesting Bill. Thanks. | | |
#67093 10/14/2006 12:26 PM | Joined: Nov 1995 Posts: 5,713 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,713 | Howdy mazdabon2nd We have a couple of Bolters who have done, or who are doing, diesel swaps. Grigg Mullen is in the process of putting a Detroit into an AD Big Bolt right now and has several threads about it in the Big Bolt forum. The latest update is located at this link A 3800 with a small Detroit would be cool. I have kicked around an idea of getting a Cummins and tranny out of a Dodgebolt but that one's never really gone beyond the idea phase... Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
#67094 10/15/2006 12:37 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | That 59 GMC rocks! Well, except for the diamond pattern on the front bumper... Can't we discipline them for doing that?
delete my account and pictures
#67095 10/15/2006 3:58 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | This thread more properly belongs in the Big Bolts forum so I am moving there. I let it run thinking it would die out quickly but obviously it hasn't so it now goes where it belongs. | | |
