1 members (baldeagle),
96
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | 1949 216 ,W1 carb rebuilt 3100 chevrolet
seems after sitting ,there is no gas in bowl,at least that is what it is acting like.
A little gas manually into carb and starts then dies , could the fuel be leaking out ?
Dennis | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | this sounds to me like the fuel pump has quit, or the filter is plugged, if its been sitting for a while the filter maybe plugged with crap gas. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | after 2 weeks, probably not a clog fuel pump is 1 year old | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I would take the pump out and pump it by hand, if it works, maybe the needle in the carb is stuck open, any gas in the oil ?
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | i'll check, but actually does not seem to be any gas coming out of carb and the filter bowl next to carb is full | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | You could just un hook the fuel line at the carb and see if the pump is working. The glass bowl is just a strainer/seperator really. It doesn't have a sintered bronze filter inside the carb inlet does it? It doesn't take much to plug those. Maybe the float is stuck in the full position and isn't allowing any more fuel in.
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Is this a repeat problem? If its every week or so that you try and start it, its most likely nothing to worry about. Hows it run once its started? The modern gas we run now evaporates much quicker then the older gas did. My Mono-jet will dry out after two or three weeks.
Joe | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Joe H is right, the gas of today is CRAP. What I do with my truck (same year and carb)is with the ign. off push the starter pedal for a few seconds, then switch on the ign., pull the choke out full, pump the gas pedal 3 times and push the starter pedal. If it dos"nt start, pump the gas pedal 1 or 2 times more and try the starter again. I do this every saturday in the summer.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I'll try that ,and also check the float
does someone have adjustment instructions for the W1 ? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 |
Ed
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Like andy says, remove the fuel line from the carb & crank the engine. A strong squirt of gas should come out. If so check your float & needle valve. Some Carters have a tiny screen in the needle valve that can get plugged up. If there is gas in the bowl but the accel. won't squirt you have something wrong with the accel. pump. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | What is the school of thought around a simple in-line electric fuel pump? My truck does the same thing and it seems like it takes a while to re-prime and then it is fine. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | thanks, I think the metering rod jet assembly is wrong and fuel is going by.
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Looks like the metering rod jet assembly is wrong, allowing fuel to drain out of bowl.
Since that is an area untouched, I can only think that somewhere down the line the correct metering jet assembly was removed.
Now to find a matching rod and jet assembly for this. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Anyone know where to get these ?? | | |
