| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | So I've been reading up on what everyone says about tires. Basically stick to radials if you want to use it as a daily driver. I have a 58 Apache 3100 Fleetside that is completely stock, with exception of a CPP front disc brake kit.
I've got the wheel spacers to push out my original 15" wheels to clear the calipers.
Now what kind of tire? I need it to be tall, as it's the 3 speed, but I want it to be wide enough to handle well. Any ideas guys? Any first hand experience?
I appreciate your input! Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | wide doesn't make it handle better, radials do - tall = truck tires, not P type
Bill | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Just a guess but it was likely 7:10x15 stock so I'm thinking 225R-75x15 would be about the same nowadays. An 85 series would be taller if there is such a thing in a 225. I agree with squeeze that going wider is not a good thing and will make it steer like a log truck. In other words don't try to re-engineer the thing. The builders knew what they were doing. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I used 215/85/16s on mine and they look and drive great.
Pete | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Pete,
How much clearance is there at the front fenders when turning with the 215/85/16.
I removed 3 leaves from all 4 leaf springs so I'm not sure if they will work on the front.
The rear shouldn't be a problem.
-Tom
1950 Chevy 3100 w/ 1956 235
