4 members (Rusted Nut, 39Master85, BC59, 1 invisible), 92 guests, and 1 robot.
Topics128,132
Posts1,056,376
Members48,441
So I've been reading up on what everyone says about tires. Basically stick to radials if you want to use it as a daily driver. I have a 58 Apache 3100 Fleetside that is completely stock, with exception of a CPP front disc brake kit.
I've got the wheel spacers to push out my original 15" wheels to clear the calipers.
Now what kind of tire? I need it to be tall, as it's the 3 speed, but I want it to be wide enough to handle well. Any ideas guys? Any first hand experience?
I appreciate your input!
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
wide doesn't make it handle better, radials do - tall = truck tires, not P type
Just a guess but it was likely 7:10x15 stock so I'm thinking 225R-75x15 would be about the same nowadays. An 85 series would be taller if there is such a thing in a 225. I agree with squeeze that going wider is not a good thing and will make it steer like a log truck. In other words don't try to re-engineer the thing. The builders knew what they were doing.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I used 215/85/16s on mine and they look and drive great.
Pete
Pete,
How much clearance is there at the front fenders when turning
with the 215/85/16.
I removed 3 leaves from all 4 leaf springs
so I'm not sure if they will work on the front.
The rear shouldn't be a problem.
-Tom
1950 Chevy 3100 w/ 1956 235
