| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66785 10/04/2006 4:24 AM | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | I have a 57 3100 with its orginally designed brake system. If I have to hit my brakes really hard in traffic (and this happens more and more now) the truck pulls hard to the right. I have to really hold on tight to keep it straight. I had a shop look at all the brakes and I am told that all of the shoes look ok and all of the cylindes are working etc.. I have owned this truck since 1989 and have never replaced the shoes or turned the drums. I replaced the master cylinder two years ago and there is no leakage of fluid. Whats the problem? Should I just go ahead and replace the shoes and turn the drums? I want to drive this truck more and more now that I have a complete engine and tranny overhaul so it needs to be safe. Thank you, Kevin | | |
#66786 10/04/2006 4:38 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kevin,
Did the shop charge you for that diagnosis? :rolleyes:
Stuart | | |
#66787 10/04/2006 4:44 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Did they at least try to adjust the brakes, and/or have you ever adjusted them? | | |
#66788 10/04/2006 5:27 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I would first jack up the front end of the truck, have someone step on the brake pedal and see if both front wheels are "locked up". Even spin them fast and have someone apply the brakes. If one stops and the other doesn't, you may have a stuck wheel cylinder in the one that continues to turn, or the one that stops could have a leak causing fluid to get on the shoes making it grab upon apply pedal pressure. If they both stop, manualy adjust the brakes and retest. Somewhere in this process, the problem should show up. Some of the other 'Bolters may have some other suggestions. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#66789 10/04/2006 9:16 PM | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | He adjusted them and said that they were alot better than his first test drive but I am still not happy with them. Thanks 6cylinders I will try that. I did find some past info on this when I did a search of the forums. I know more than I did. I need to get to the bottom this. I have a feeling just replacing the old shoes and turning the drums will help but I want to eliminate any other reasons too. Thanks to all. | | |
#66790 10/04/2006 9:32 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Ya know, they may have told you correctly about your brakes. You may have front suspension wear. and when you apply your brakes it changes the alignment enough to make it pull.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#66791 10/04/2006 9:40 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Kevs57,
I tell this story all the time, but when I brought my 46 home and started working on the brakes, I was convinced the shoes were fine. The shoes were new, but after sitting for 20 years, they had absorbed too much grease. I could never get them to work right. Even after proper adjustment, they still hung up, pulled and just did not work. I changed out the shoes and my problems were solved. It took me awhile to get to the point of changing out shoes even though they had almost 100% worth of pad left on them.
For what is is worth, that is what worked for me. | | |
#66792 10/04/2006 10:19 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | These are all good points. Another possibility is defective brake hoses. They can swell up inside & restrick the flow of fluid. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#66793 10/04/2006 10:40 PM | Joined: Apr 2005 Posts: 15 Junior Member | | Junior Member Joined: Apr 2005 Posts: 15 | I think Wrenchbender has it here. I had similar problem years back. The rubber lines were swelled on the inside restricting flow. I replaced them and the brakes worked perfectly. I cut the old lines in-to, and the lines on one side were completely swelled together on the inside restricting flow. They looked good from the outside. You might want to check to see if you are getting fluid to that side before you start replacing hoses. I hope this helps.
Mark... | | |
#66794 10/05/2006 3:12 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would have the alignment checked. Improper adjustment can cause pulling and torque steer if it were front wheel drive. Check ride height first, it will affect all other adjustments, Scott | | |
#66795 10/06/2006 4:14 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | if pulling to right..the left front prob. needs adjusted up or bled. | | |
#66796 10/15/2006 5:01 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Also, check the entire vehicle for crushed or damaged steel brake lines. Sometimes due to an accident or improper lifting a brake line can get smashed. I did some work on a 57 convertable a while back that the previous owner had intentionally crimped a rear brake line to shut off the flow to a rear wheel that had an axle seal leak. It stopped the rear from locking up but ultimately caused a severe pull in the front. Fred
#66797 10/16/2006 12:33 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you don't know the age of your rubber lines it is probably a good idea to replace them. I would resist having the drums turned. most of the time people turn them with no real reason to. That just makes them wear out sooner. However, if they have really bad groves in them, or are not round any more you should turn them, just don't do it for the fun of it, save your money if they are still good. | | |
