4 members (Gdads51, MickeyP, Jon G, KCMongo), 69 guests, and 0 robots.
Topics128,051
Posts1,055,705
#667100 08/02/2010 1:56 PM
Pulling the torque tube from my 38. Cant get access to u joint,the propeller shaft should move to the rear to give me access to the u joint bolts,right? The tube has been bent and braced with angle iron a couple times. could this cause the issue?
1937 Chevy 1/2 ton panel
I just cut the shaft. It had been cut two other times. I guess you must pull either engine or rear end to access u joint.
...I seen something like this a while back on a 37 we were taking apart. Seems the po had used perhaps a heavy duty 4 speed tranny and we could not get the u-joint to come out. There were not "indentions" on the rear collar of the tranny like on most 1/2 tons. So, we did the same thing. Pulled the rear end out.
