1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Pulling the torque tube from my 38. Cant get access to u joint,the propeller shaft should move to the rear to give me access to the u joint bolts,right? The tube has been bent and braced with angle iron a couple times. could this cause the issue?
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I just cut the shaft. It had been cut two other times. I guess you must pull either engine or rear end to access u joint.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I seen something like this a while back on a 37 we were taking apart. Seems the po had used perhaps a heavy duty 4 speed tranny and we could not get the u-joint to come out. There were not "indentions" on the rear collar of the tranny like on most 1/2 tons. So, we did the same thing. Pulled the rear end out. | | |
