1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66572 09/28/2006 4:20 AM | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | Hi, someone i know has a 250 and a th350 from a 70 chevelle for $100. The current 235 needs a rebuild and i could use some imput on what to expect installing them into my 54 that also has three on the column?
Tony
old iron vs. new plastic....no brainer! TECH WANTED: on S-10 frame swap PARTS WANTED: 54 Visor, weather strips.. PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate 1954 GMC 3100 | | |
#66573 09/28/2006 4:25 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm not up on GMC's, does it have a closed driveshaft (torque-tube)? Scott | | |
#66574 09/28/2006 12:17 PM | Joined: Sep 2006 Posts: 2 New Guy | | New Guy Joined: Sep 2006 Posts: 2 | I have a 1950 GMC with a '74 250. The truck came this way. It is bolted up directly to the old 3 spd and torque tube rear end, but has side engine mounts added. I do not think the bell housing is original since it does not have mounts for the crossbrace. I think for an auto, you'd want to add the side engine mounts and a new rear tranny mount. You also have to swap out the torque tube rear end. | | |
#66575 09/29/2006 2:14 PM | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | im not sure what rear end or drivshaft it has
