4 members (32Fordpuchoptop, 55shaker, TUTS 59, 1 invisible), 70 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#66531 09/27/2006 7:38 PM
59 1/2 T 235.
On another old vehicle site they say to only fill the rad till the top of the tubes are covered. They say the top of the rad is for expansion, and that if you fill it to the cap you are just wasting antifreeze.
Comments?
Also, what rad cap pressure should I look for when I get a new cap, and what temp thermostat.
I know I should look it up, but several times the hands-on experience of bolters is a little different than the manual. I always checkwith you guys.
"Happiness equals reality minus expectations" - Tom Magliozzi
#66532 09/27/2006 8:16 PM
I keep mine about 3/8-1/2" below the cap, but I'm running an expansion tank with it. Probably about 1" below the cap would be fine if you don't have a tank. I'd keep with the stock 7 psi cap to prvent any problems with the rad, and a 180-185 t-stat. A 160 was used stock, that's what I'm running and haven't had any problems.
Try to stick to the green antifreeze, or the universal "add to any" type. The pink/orange stuf can be rough on older type water pumps that were not designed to use it.
Bill Burmeister
#66533 09/28/2006 12:12 AM
Ex Hall Monitor
Ex Hall Monitor
That's a recomendation for an unpressurized system without an overflow bottle. My 38 is unpressurized and I fill it a little over core without problem. I run a 160 thermostat.
#66534 09/28/2006 2:15 AM
I'm with Tiny - a little over the core works for me with no overflow ever. I use a 7 pound cap.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#66535 09/28/2006 2:32 AM
I won't disagree, it's more like around 2-2 1/2" down from the neck. A little low to allow for expansion on a non-pressurized system or one without an overflow probably doesn't hurt. On the TFs, when filled to the spec for capacity, they are usually around an inch or so below the neck.
Bill Burmeister
#66536 09/28/2006 3:21 AM
Since mine are not show queens, I fill them up until full and let them self level the coolant. I hose off what pukes out and all is good,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#66537 10/02/2006 3:02 AM
Installation of a $10 overflow bottle saves a lot of overflow and wasted antifreeze on the driveway. I run a 7 lb cap and put a little antifreeze in the bottle and never have to worry about radiator coolent level again as it takes care of itself!!! and this is in a Texas climate with over 100 degrees most of the summer...
Green Machine
