3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#665135 07/26/2010 12:29 AM
this time i have the names right. i would like to know if anyone has removed the gas tanks from a 1952 panel and relocated a larger tank where the spare tire is hung? it seams the only place to put it until i can buy two new tanks for my 9435. my concern is safety.the tank would be between the bumper and the diff. comments??
.... I decided to put a new tank back in my original position on my 52panel. Its between the chassis, close to the rear wheel for blocking a hit. I figure its about safe as it gets. However, I will admit it makes running dual exhaust kind of hard.
Apprentice
Apprentice
I too am wondering about a rear mount tank. The 70 Mustang tank is sometimes used on p.u.'s I would suspect it would work but
do not know for sure. I am looking at a Jaz tank from speedway to put in the original location until I can afford a JC tank.
http://www.speedwaymotors.com/Street-Rod-Fuel-Cell,2524.html
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Try a late 70's to late 80's/early 90's Suburban/Blazer tank.
You cab get them up to 40 gallon & to install it you have to move the back brace to the rear & trim the frame about 1/2inch...joe
#665355 07/27/2010 12:08 AM
thanks for the information. i have since been given a new long 80's chev tank and a older chev pu tank that stands along a wall. i think i may mount the older tank inside the panel above the wheel well behind the passenger then work on getting the price of two new repo originals.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Good luck, but I can tell you this.
I have an S10 frame under my AD truck & the S10 frames are a tad wider then the AD truck frames & those long tanks won't fit....joe
#665980 07/29/2010 12:53 AM
I used a tank from 83 El Camino and it fits in the cavity behind the rearend between chassis rails on my 49 Suburban The filler pipe will extend behind tire and out the fender well. If i can find the pictures I will post them.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
i would like to see the pixs i am trying too get this truck as a daily driver but i have had so little time to anything finished. i will be making do until i retire and then do a complete frame off.
