1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#664019 07/21/2010 4:05 AM
Folks -
Got the 47 1 ton on the road! I rebuilt the carb yissterdiy, got it all back together and drove the truck home from the In-Law's ranch late this afternoon. The truck wanders like crazy and has VERY low power - I *may* have hit 25 MPH on the way home, but it took some coaxing of the accelerator to gain any meaningful engine speed - barely enough to qualify for "same day service"...
I'll have to do a tune up and run the valves. The engine RPM picks up off idle okay, but there's definitely a flat spot at 12 to 1500 RPM.
Got to change all of the fluids and do a chassis lube as well. Oh boy! Sure is fun having "Matilda" finally sitting in the driveway, pulling down property values 1 block in all directions.... Yipee!
John Moorhead
Rose Davidson
47 Chevy 3800 (235)
(not for sale)
Good Luck ,and now the real fun starts.
Pete
Originally Posted by Knedert
..... pulling down property values 1 block in all directions....
Sometimes that's the most fun part of all!! dance grin grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Congrats! As far as the flat spot, I'm guessing it's fuel starvation. Check the fuel pump, filters, lines and tank. I bet you'll have it running strong in no time.
...and the vacuum advance.
Good call.
