1 members (Opelika Tom),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 74 | Folks -
Got the 47 1 ton on the road! I rebuilt the carb yissterdiy, got it all back together and drove the truck home from the In-Law's ranch late this afternoon. The truck wanders like crazy and has VERY low power - I *may* have hit 25 MPH on the way home, but it took some coaxing of the accelerator to gain any meaningful engine speed - barely enough to qualify for "same day service"...
I'll have to do a tune up and run the valves. The engine RPM picks up off idle okay, but there's definitely a flat spot at 12 to 1500 RPM.
Got to change all of the fluids and do a chassis lube as well. Oh boy! Sure is fun having "Matilda" finally sitting in the driveway, pulling down property values 1 block in all directions.... Yipee!
John Moorhead Rose Davidson 47 Chevy 3800 (235) (not for sale) | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Good Luck ,and now the real fun starts.
Pete | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | ..... pulling down property values 1 block in all directions.... Sometimes that's the most fun part of all!!  | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Congrats! As far as the flat spot, I'm guessing it's fuel starvation. Check the fuel pump, filters, lines and tank. I bet you'll have it running strong in no time. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and the vacuum advance. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | ...and the vacuum advance. Good call. | | |
